Hello, could you help me to update the ACM module of my FIESTA ST MK8?
I currently use version 2.4.5 beta 3 and the OBDlink EX interface but the update section of that module is not available.
ACM module update - Fiesta ST MK8 (2020)
sorin.popescu
- Vehicle: Ford Focus MK4, 1.0L, 125hp, 2018
Re: ACM module update - Fiesta ST MK8 (2020)
Do you have sync 3 (with apim) or sync 2.5 (ACM CTR)?
SYNC 3.4 NATIVE, FORD ETIS warns me of the availability of an update of the AMC module, correctly detected by FORSCAN, but there is no update section as for the other modules.
davetcollection
- Vehicle: Focus 2017 ST-Line 1.0 Auto 6F15
Delete profile and connect to vehicle again to see if it appears
I create a new profile every time I connect
I'm also seeing the same thing on my 2013 NA C-Max Energi. I had the module firmware update option in 2.4.5b3 early on in February and was able to update the calibration then. No changes since then. Same version loaded but no longer see the module update option. OBDLink EX as well here and I've run a fresh profile a few times.
The intent, despite being on the latest calibration now, is to downgrade to an older one as the new calibration is causing some audio level issues (analog FM and HD FM here in the US are wildly different volume levels compared to before the update).
Looks like it may have been a bug with 2.4.5b3. I was provided a new 2.4.6 test build and the module firmware update option returned for the ACM and I was able to successfully run the update.
I tried again with build 3.4.6 20220129 test and the section to update the AMC module is not available, the other modules are regularly updated.
