2011 Ford Fiesta tcm reprogramming
JPeterman
Vehicle: 2015 F250 crew XL 6.7 4x4
Post by JPeterman »
Is there anyway to be able to reprogram a new blank TCM for a 2011 Ford fiesta without having to go to Ford?
davetcollection
Vehicle: Focus 2017 ST-Line 1.0 Auto 6F15
Re: 2011 Ford Fiesta tcm reprogramming
Post by davetcollection »
Possibly, I think save old one before removing
Then recover new one after installing asbuilt
I would imagine you need 2.4.5, good lead and paid license
Someone will be along to correct me, I'm sure
JPeterman
Post by JPeterman »
I have updated to 2.4.5 and I have obdlink ex adapter. I have the Extended License. It finds the TCM module and says it needs a firmware update but once started it says loading SBL to primary module then shows Service procedure has been interrupted. I am still new to using forscan, am I missing a step? Thank you for your help
davetcollection
Confirm you have all the software ready for install (green dots)
Confirm adapter is at latest level and connection settings are correct
Force programme unchanged and stop activity on buses ticked.
Confirm battery charger connected to vehicle
rodorodo
Vehicle: Ford Fiesta 4 cyl , 1.6 2014
Post by rodorodo »
JPeterman wrote: Sun Mar 13, 2022 9:52 pm I have updated to 2.4.5 and I have obdlink ex adapter. I have the Extended License. It finds the TCM module and says it needs a firmware update but once started it says loading SBL to primary module then shows Service procedure has been interrupted. I am still new to using forscan, am I missing a step? Thank you for your help
I have the same issue, did you solve it? :|
