Firmware update for 2005 Ford Freestyle
cutter4320
Vehicle: 2005 Ford Freestyle
Post by cutter4320 »
I'm running Forscan V2.4.6 beta with a paid license and am connecting with a Vlinker FS cable. Under the configuration and programming tab I only get the "As Built" option for my my TCM that I need to update firmware on due to replacing a failed TCM. Am I doing something wrong or is this vehicle not supported for firmware updates?
Re: Firmware update for 2005 Ford Freestyle
Read this page from top to bottom.
https://forscan.org/forum/viewtopic.php?t=18751
Use the recommended adapter with the laptop, laptop powered to house/shop current AND a clean stable power supply on the battery.
QuikFord
Vehicle: 2018 F150 3.5 GTDI 2013 MKS 3.7 NA 2WD
Post by QuikFord »
2005 Freestyle, Montego and Five Hundred are notorious for flash issues with aftermarket equipment, even with Ford FJDS/J2534. May want to source OEM programming for this particular year.
2013 Lincoln MKS 3.7 TiVCT 2WD
2005 F150 STX 4x4 4.6L
