Ford Explorer 2007
agenttalha
- Vehicle: Ford Explorer 2007 4.0L
Ford Explorer 2007
There is no option to update module firmware for the modules of ford explorer 2007 4.0L in forscan. is there any way to add it
Re: Ford Explorer 2007
That is still being worked on by the FORscan team! It willl be added to the 2.4.x version branch when the team can get the process to run reliably! In this generation of modules it is likely that the only Firmware update-able modules are the PCM and TCM!agenttalha wrote: Mon Oct 17, 2022 6:35 pm There is no option to update module firmware for the modules of ford explorer 2007 4.0L in forscan. is there any way to add it
Also be aware that the process for PCM updates also requires an adapter with the DLC pin No. 13, 18 Volt signal capability Called FEPS! These include a Ford VCM2 or 3, a J2534-2 adapter like the CARDAC+(Ford Lists this adapter line as working for FRDS/FJDS) or a vGate vLinkerFS!
agenttalha
Alright thank you very much. Yes i have ford vcm 2 and i have updated modules for my taurus
