i have one question.
In the newer versions of forscan (for e.g. 2.4.6) i can see the factory firmware of the connected car. So before updatating an module the Factory tab and the current tab of Firmeware version are the same. After an update i can see in the factory tab the old module firmeware.
Now i need an check of factory firmeware without the car, only FIN is available. I only need the installed Version from factory side to update an other car with this version. Download of Dsfm File is no problem..
So is it possible in this usecase?
Is it an idea for an next version?
Do somebody now where i can find this informaion on a other tool? (I know it only from UCDS but thats not available)
Thx.
BR
Factory Firmware only with FIN
- LaForge
- Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
- Contact:
Re: Factory Firmware only with FIN
I miss some "Offline" functions too.
With UCDS you can Plug in Adapter and edit XML Files with Direct Config weithout the car.
Then you can save them back to file and write them into car if you are connected.
Also Firmware Upgrades can be load without car.
It will be nice to get an OFFLINE Mode in Forscan, whrer you can load the Profile and do some changes without the car.
Best regards
Karsten
Best regards
Karsten
Changed on my 2011 Focus:
Hill Assistant, Auto High Beam, Sync 3 with Navigation, Traffic Sign recognition, Lane Keep Assist,
Lane Centering Aid, Rain Sensor, Ambient & Footwell Light, FL ST-IPC, BLIS, HSW from Focus FL.
