2023 Ford explorer : Cluster language
Timber911
Vehicle: Explorer Timberline 2.3l 2023
Post by Timber911 »
I updated the APIM on the 2023 explorer but it also reset the cluster language. Now, I just can't find the damm Language setting for the cluster.
No, its not innthe cluster settings display because I only have oil reset there.
Anyone have an idea where it could be located, what module to look?
Im bilingual but the wife is not and would need to change it back to french.
Re: 2023 Ford explorer : Cluster language
ZuMa
Vehicle: FORD EXPLORER 6G
Post by ZuMa »
Timber911 wrote: Tue Feb 21, 2023 11:49 pm I updated the APIM on the 2023 explorer but it also reset the cluster language. Now, I just can't find the damm Language setting for the cluster.
After updating sync, you need to change the region to the one you need in IPC.
After that, install the language you need in sync again.
