Use Forscan on-the-shelf
MayTheFordBeWithYou
Vehicle: Ford Mondeo MK4 Early Facelift 09/2010
Post by MayTheFordBeWithYou »
currently one needs to connect to the car in order to use Forscan.
I'd like to use some functions in my simulation bench where i experiment with modules.
How can i get Forscan to fully start and use module programming outside the cars network?
I've tried to simulate ignition HS-CAN messages but it seems not to be sufficient.
Re: Use Forscan on-the-shelf
FORScan connects to the PCM primarily, build a network with HS and MS controllers via network connections.
Wire the two networks with a DLC.
