Forscan injector values
GiuSIM
Vehicle: Ford Focus MK2,1.6Tdci,80kw/109HP,2006
Post by GiuSIM »
Hello.
I can't find the injectors menu to read the values ​​and I had to update my adapter and which ones. Thank you.
Mein adapter is not compatible with this car.What can i change?
GiuSIM
Re: Forscan injector values
Post by GiuSIM »
What for driver i need?
lohberg57
Vehicle: Ford Grand C-MAX 1,6TDi, EZ:2011
Post by lohberg57 »
maybe this one is good. It is old technic, but works.
https://www.amazon.de/Forscan-Diagnoseg ... C95&sr=8-8
Ford grand C-MAX 1,6TDi, 2011, Black Panther
lohberg57
Post by lohberg57 »
GiuSIM
Post by GiuSIM »
Thank you.I have the same.Wenn i connect to the car in Protokoll is: THE ADAPTER IST NOT RECOMMENDED FOR THIS CAR.
GiuSIM
Post by GiuSIM »
I have driver CH340 instaled.Its a driver problem?
GiuSIM
Post by GiuSIM »
What can i do?
GiuSIM
Post by GiuSIM »
https://www.ebay.de/itm/125326088975?mk ... dia=FB_MSG
I have this adapter.It is good for Ford Focus mk 2 ?
Itry to connect the car and it says Adaptar not commpatible with your car.
support_team
Vehicle: Support and moderation team
Post by support_team »
GiuSIM wrote: Mon Apr 24, 2023 12:05 pm
What are possible problems if I use "regular" ELM327 instead of "recommended" adapter?
https://forscan.org/support/show_conten ... ecommended
GiuSIM
Post by GiuSIM »
Hy.
I bought OBDLINKEX.Where can i find injektor value?
