2005 lincoln ls pcm
drexx0929
Vehicle: licoln ls 3.0 2005
2005 lincoln ls pcm
Post by drexx0929 »
i have the vgate vlinker fs i have tried to access pcm ab data of course didnt work. should i have access with 2.4.7?
Re: 2005 lincoln ls pcm
Check your tools and laptop, As-Built is available for Lincoln models.
No screen images available?
No fault codes?
Lincoln As-Built.png (27.31 KiB) Viewed 2211 times
drexx0929
Post by drexx0929 »
So when I was utilizing previous version 2.3.53 I was not even able to see as built data but with 2.4.7 I should be able to access the info?
support_team
Vehicle: Support and moderation team
Post by support_team »
drexx0929 wrote: Sun May 28, 2023 8:38 am So when I was utilizing previous version 2.3.53 I was not even able to see as built data but with 2.4.7 I should be able to access the info?
You don't need FORScan 2.4, it's only for module firmware update. Please clarify the problem you get.
drexx0929
Post by drexx0929 »
I am wanting to program a new pcm but I am not seeing anything for the pcm to save as built data
Explain the "new" PCM.
Is it a dealer purchase or "rebuilt / reprogrammed.
A blank PCM will not have any features available.
A blank PCM will require a motorcraft subscription to write the VIN and apply the required strategies.
Then the Keys and Parameter Reset is required.
At least the details came evident after the 4th post.
drexx0929
Post by drexx0929 »
i currently have the defective pcm in the vehicle I am able to see the vin block id but i cant see the as built data so that i can save that file and load it to the replacement pcm that i purchased
drexx0929
Post by drexx0929 »
i am new to forscan so if you could give me some direction as to how i can program a new pcm
