SBL loading error
ZanyDruid
Vehicle: 2015 Ford Police Interceptor Sedan 3.7L
SBL loading error
Post by ZanyDruid »
Hi for some reason when I try to program any module i get SBL error, service has been interrupted how do I fix this
support_team
Vehicle: Support and moderation team
Re: SBL loading error
Post by support_team »
Please address your problem to the support team by e-mail and provide debug information for analysis as described here:
http://forscan.org/contactus.html#debug_info
ZanyDruid
Post by ZanyDruid »
I have been. They can’t get me a solution
support_team
Dealership scanner can only update firmware in the following modules of your car (Escape 2011): PCM, IC, PSCM. Other modules, even although information about their firmware can be found, aren't programmed by the dealership scanner. As a result, FORScan has no proper security information for these modules. From our experience, it is not very good idea to program such modules as the chance to damage them is too high.
ZanyDruid
Post by ZanyDruid »
It can update APIM, Ford IDS also gives that option to update however I can’t download the firmware file from IDS
