Possibly bricked ABS module on 2012 Fiesta
PancakeFord
Vehicle: 2012 Ford Fiesta
Post by PancakeFord »
I broke the ultimate rule "If it ain't broke, don't fix it" by attempting to upgrade firmware on ABS module.
This is a screenshot I grabbed after failure, should have snapped one before...
Full log attached also but this is the log for first failed flash of ABS module
Code: Select all
(OK) [15:33:51.040] ABS Module firmware update has been started
(WARN) [15:33:51.053] Reading vehicle info...
(WARN) [15:34:15.602] Downloading firmware files from the Internet...
(OK) [15:34:17.634] Downloading AE81-2D052-AA: OK
(OK) [15:34:19.680] Downloading CE81-2D053-AB: OK
(OK) [15:34:19.713] Downloading CE81-14C602-AC: OK
(WARN) [15:34:36.493] Total size: 577.2 Kb. Estimated duration: 1m - 2m
(WARN) [15:34:39.795] Loading SBL to primary module...
(WARN) [15:34:40.635] Loading block 1/1...
(OK) [15:34:40.753] SBL loaded successfully
(WARN) [15:34:40.773] Loading firmware to ECU: Strategy CE81-2D053-AB
(WARN) [15:34:40.774] Erasing block 1/3...
(WARN) [15:34:40.972] Erasing block 2/3...
(WARN) [15:34:41.164] Erasing block 3/3...
(WARN) [15:34:43.043] Loading block 1/7...
(WARN) [15:34:43.163] Loading block 2/7...
(WARN) [15:34:43.372] Loading block 3/7...
(WARN) [15:34:43.404] Loading block 4/7...
(WARN) [15:34:44.683] Loading block 5/7...
(WARN) [15:34:44.701] Loading block 6/7...
(WARN) [15:35:40.874] Loading block 7/7...
(OK) [15:35:41.003] Firmware loaded successfully
(WARN) [15:35:41.017] Loading firmware to ECU: ECU Configuration/Base Configuration CE81-14C602-AC
(WARN) [15:35:41.018] Erasing block 1/1...
(WARN) [15:35:41.308] Loading block 1/3...
(WARN) [15:35:41.398] Loading block 2/3...
(WARN) [15:35:43.468] Unable to obtain downloaded block checksum from ECU, so cannot verify download
(WARN) [15:35:43.472] Operation failed, retrying...
(WARN) [15:35:43.587] Operation failed, retrying...
(WARN) [15:35:43.704] Operation failed, retrying...
(ERR) [15:35:43.915] Loading firmware failed
(ERR) [15:35:44.876] Service procedure has been interrupted
As a last resort I tried recovery flash without checksum check, and then disconnected the ABS module and reconnected it when prompted to.
Logs will show same results for multiple attempts. Flashing previous version also did not work.
failed_abs_upgrade_and_brick_module_disconnect.txt
(23.03 KiB) Downloaded 359 times
PancakeFord
Re: Possibly bricked ABS module on 2012 Fiesta
Any thoughts on recovering this ABS module?
I have tried to program all available options, including the factory, and none of them complete.
Loading blocks 1-5,7 complete pretty fast and 6 takes the most time to complete.
Skipping checksum verification does not work either although I am not sure if checksum error is for that.
Going to look for a used ABS module meanwhile as driving the car with no ABS, speedo, and what feels like 50% throttle max is no fun.
PancakeFord
Never mind, I got it now.
Flashing SBL, Strategu, and ECU Configuration all at the same time seems to fail. After flashing to latest available firmware and receiving a failure, I flashed Custom with latest SBL and ECU Configuration selected. Checked recovery, skip checksum, and unchecked force flash of same VBFs. This was very quick and flashed with no issue. Car restarted and everything is back to normal.
I must have missed a note somewhere that some modules require separate ECU configuration flash.
Airborne_Ape
Vehicle: F150 Hybrid 2021
Post by Airborne_Ape »
News to me, but I'll keep it in mind for future troubleshooting.
BakerAuto
Vehicle: Fiesta, 1.6l, 2013
Post by BakerAuto »
When flashing custom where did you get the latest SBL and ECU config. ? I’m currently in the same boat right now with a 2013 Fiesta.
PancakeFord
BakerAuto wrote: Sun Sep 17, 2023 11:27 pm When flashing custom where did you get the latest SBL and ECU config. ? I’m currently in the same boat right now with a 2013 Fiesta.
I just used the download in the forscan.
warleyrsan
Vehicle: new fiesta 1.6 2012
Post by warleyrsan »
Man, you saved my life :D
Thank you!
