Hello ForScan community,
Vehicle :
Ford Kuga 2.0 Diesel 180hp year 2017.
I have this error code in the DTC and I can't get it cleared.
But everything seems to be working.
I ran a self-test with ForScan the APIM module and the tacho module and according to the test there are no problems.
The strange thing I have is that (no exact rhythm recognizable) the battery is suddenly empty.
Replaced the 6 year old battery with a new one and reset the BMS via ForScan.
The same picture with the new battery.
Sometimes after 2-3 weeks the battery is suddenly empty, sometimes after a short drive to work.
So it starts without any problems, drives 30 minutes, goes shopping (30 minutes), wants to start again and "click" nothing works anymore.
I now think that this phenomenon has something to do with the error code?
Does anyone know the problem here?
I'm thankful for every advice.
Best regards
DTC Error read - APIM
DTC errors: 1
U0155 - Lost Communication With Instrument Panel Cluster Control Module
U0155 - Lost Communication With The Instrument Panel Cluster Control Module
Ext.Status: 0B - Minimum Control Limit Not Reached.(DTC) Present at Time of Request.
00- Error status not found in base....
DTC / APIM U0155:00-0B
Re: DTC / APIM U0155:00-0B
Check out the BMS and the battery connections,it could be related to corrosion in body negative connections.
