2023 Super Duty Exit Warning System Disable
So my truck has the factory bed removed for a flatbed, And I was able to turn off the blind spot and cross path detection in the IPMA, APIM and IPC. But I still have a Exit warning system fault being displayed in the instrument cluster. There are no parameters for turning this off in any of the modules I found. At least if I could turn off the warning in the IPC that would be great. Thanks in advance for any developers looking into this for me
twisterrescue
- Vehicle: 2003escapeltd
Re: 2023 Super Duty Exit Warning System Disable
HI what is exit warning ? is it a push to start ? meaning walk away runnung w/ key in pocket .that pariminter might be in the bcm files .
Exit warning uses radar sensors to alert you to traffic objects approaching your open door.
Exit warning detects traffic objects such as vehicles, cyclists, scooters and motorcycles that approach your vehicle from the rear and cross into the exit warning zone. The exit warning zones are along the left and right sides of your vehicle and extend slightly past a fully open door. But, the system cannot detect animals, slow moving pedestrians or any type of stationary object.
See the link below from the online owners manual and at the bottom of the page you can click through the pages that explains the system in full detail
https://www.fordservicecontent.com/Ford ... ldtype=web
