ipc changes
Anviltester
Vehicle: 2020 Mustang Gt
ipc changes
Post by Anviltester »
i changed some things in the ipc menu (not the as built - just the enable/disable) and want to go back to as stock (before i disabled stuff). I tried restoring the as built but it didnt change the reg ipc menu stuff. is there a way to do that?
FujiiX
Vehicle: Ford S-Max, 2.0 140kW, 2020.
Re: ipc changes
Post by FujiiX »
Have you backed up IPC before?
Don Ridley
Vehicle: 2016 Transit Connect
Re: ipc changes
Post by Don Ridley »
Depending on what you changed and the vehicle model, your plain menu changes in the IPC may have changed data in multiple modules. Careful Forscan users make backups of ALL module as built data before doing anything. Then it's possible to restore data if necessary.
Anviltester
Re: ipc changes
2020 mustang gt. i didnt make a backup - just have the as built downloaded from ford. its a full road race car but has to use the stock ecu and abs so im stuck with the stock wiring until I can find someone who can do a harness to run the factory abs with ford performance control pack wiring. I was disabling things I didn't need like certain gauges ive replaced with real ones and the bonging with doors open, drl off, parking sensors disabled, etc. Only made changes in the ipc section where you enable/disable (not to the as built section). Just trying to get it back to original (if possible) as I have other communication issues that im trying to work through. Im a newbie for sure with these cars so any help is appreciated. I had sent the ecu out for the pats removal but afterwards restored the ipc as built hoping it would fix the other ipc thing (it didn't) but now the pats is turned on again. fun with fords lol.
