FORScan uses PCM number to recongize the car. On new cars PCM strategy is required in fact. FORScan reads the strategy number from PCM, but if the strategy is missing in FORScan database, it shows the following dialog:
Important note: the same error will appear if the car is too new for this version of FORScan. Please make sure that you use the latest version of FORScan.
The simplest workaround in this case is to obtain factory (stock) strategy number for the car in trouble and enter this number in the dialog. Here is step by step instruction:
1. Go to the Motorcraft site As Built page:
Please note Ford may ask for additional information, such as your country. Please sumbit all the necessary information, it is not difficult.
2. Enter VIN of the car (we recommend copy and paste, to avoid typos) and fill Captcha field, submit the request.
3. Press the "DOWNLOAD FILE" button at top of the page and store the file in a folder you can find it later in.
4. Open the file downloaded on step #3 with any convenient XML viewer.
This is the most confusing step, as the downloaded file has .ab extension that is not associated with XML format in Windows, and majority of normal people don't use XML viewers in their normal work. So as a quick workaround, it does make sense to rename (or save as) the file and add .xml and the end, then click it to let Windows find some software to view the XML.
5. Using XML viewer search, find the NODEID tag with 7E0 value, the find F188 tag inside and copy it's value:
6. Copy and paste or type the value in FORScan dialog and press OK.
