PATS ISSUE b10d7:87-2f missing message bcmii
spannerman93
Vehicle: Focus 2012 1.6tdci 115hp
Post by spannerman93 »
Hi new to for-scan wondering if someone can shine some light. Short story 2012 focus 1.6tdci snapped a timing belt, replacement engine ordered and fitted. Once fitted and ready to fire and run put new battery back on. Car was sat with a low charged battery for 4months to stop alarm going of when locked. When installing new battery to the car the alarm sounded and I grabbed my key fob and pressed the open door button to silence alarm. Jumped in key in ignition to crank over to find immobiliser active message on dash. Ran forscan tool on the car and getting code B10d7:87-2f in bcmii module pats key missing message. What is the issue here has the car forgot the key codes for the keys while in a discharged state? If so is it as easy as having the keys reprogrammed to the bcm ? Two keys originals as far as I’m aware with the car. Was hoping that I could do key coding from the forscan but it’s not listed in my service options list. Many thanks to any help retaled as to where to start next with this. Jack
clautosing
Vehicle: focus mk1, 1.8 tddi,2003
Re: PATS ISSUE b10d7:87-2f missing message bcmii
Post by clautosing »
Hello. You can't perform key programing or Module Initialisation with Forscan for Ford Euro5 vehicles ex. Focus Mk3, Mondeo Mk4 2012, Kuga 2012 etc
For this you need IDS with Dealer Acount to log in.
boosted_diesel
Post by boosted_diesel »
If you have another spare key then try that.
SimonM
Vehicle: Focus MK3, Duratec, 1.6, 2014
Post by SimonM »
Hi there, did you manage to get this issue resolved spannerman93, also what was the resolution? Thanks
Vladimir_y.p
Vehicle: Ford s-max 1.6 tdci 2011
Post by Vladimir_y.p »
У меня такая же проблема. Вы решили ее?
