HS-CAN - Ford HS CAN (pins 6 and 14 of the OBDII port)
MS-CAN - Ford MS CAN (pins 3 and 11 of the OBDII port)
Full ISO15765 - support for muli-frame CAN messages, asynchronous presence requests and other features required for full-value work
Ford SCP/J1850 PWM - old Ford protocol (pins 2 and 10 of the OBDII port, see Table 1.2 here for information about usage on Ford vehicles)
Ford ISO/ ISO 9141 - old Ford protocol (pin 7 of the OBDII port, see Table 1.2 here for information about usage on Ford vehicles)
Ford UBP - old proprietary Ford protocol (see Table 1.2 here for information about usage on Ford vehicles)
FEPS - 18V flash programming signal on pin 13 of the OBDII port, required for PCM and TCM flash of majoirty of old Ford cars prior to 2011 model year (check presence of the pin 13 metallic contact in the OBDII female if you need to find out if this feature is demanded by your car)
