Unable to connect to Vehicle!!!!!!!!!!!
Jim_83
Vehicle: focus FOCUS 2 1.6
Post by Jim_83 »
sometimes I get "Unable to connect to vehicle!!!!!!!!!!!" mistake. This happens when some node in the can area disturbs the network. If I remove the IC I become able to connect to the vehicle. On the same vehicle I can connect (without removing IC) but only if I have saved before this type of vehicle. Now at the moment I'm working on Mazda 2 and the IC is broken. I removed it so I could connect to the vehicle. But I want to know if there are other solutions to connect perhaps even a single module. for example if all the nodes are broken I want to be able to connect to abs.
