Can I make my passenger window go up all the way with one press?
Rodduz
Vehicle: Ford Transit Custom 2019 2.0 130bhp
Post by Rodduz »
Hi question in the title, instead of having to hold the button can I single press it and it goes up all the way like the drivers window does?
rbentnail
Vehicle: 2013 F150STX 4x4 5.0
Re: Can I make my passenger window go up all the way with one press?
Post by rbentnail »
Check your owners manual, that's where info for my truck is, it's called "Restoring the One-Touch Up Functionality".
Rodduz
Post by Rodduz »
Just checked, don't think it's possible. Needs another relay in the door
rbentnail
Post by rbentnail »
It looks like there's a clear description in your owners manual for "Resetting the One-Touch Close". Did you do the procedure?
transit windows.png (90.17 KiB) Viewed 1329 times
jpohlman
Vehicle: 2014 Escape 2.0 2018 Fusion Hybrid, 2020 Escape Hybrid
Post by jpohlman »
You have to have window motors that support one touch up.
If you don't changing things in ForScan will not make any difference, and there is no additional relay for this.
Rodduz
Post by Rodduz »
jpohlman wrote: Wed May 29, 2024 3:23 pm You have to have window motors that support one touch up.
Anyway to find out or just try change it in forscan and try if it works?
jpohlman
Post by jpohlman »
It's not going to work.
Ford didn't randomly drop one touch up units in non-one touch up cars.
Changes have to be made in the BCM/IPC/DDM/PDM
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley »
Typical Ford design is to engineer one touch open/close into the door modules. Vehicles without this feature don't have any door modules. I don't know about the Transit Custom specifically.
