6.7 injector iqa
1970mach1bill
- Vehicle: escape, 3.0, 2003
6.7 injector iqa
Is FORscan capable of programming the injector iqa codes on the 6.7?
Re: 6.7 injector iqa
interested in this as well
Audiomediocrity
- Vehicle: F250, 6.7 PowerStroke, 390 HP, 735 ft lb 2014
I am interested also!
I can tell you with certainty that FORSCAN can program the IQA code on a 6.7L ford diesel. It did on my 2011 anyway. I just did it this evening. I wanted to try it before I actually replaced the injector just to test it out and it worked. I'm not sure if it makes a difference on what device you use but I used the cheapest VCM2 clone there is. I will be also trying it with the Veepeak ELM327 tomorrow.
I just wish that FORSCAN could do an injector buzz test for the 6.7L. I know can do it for the older trucks but no dice on the 6.7 yet. If anybody knows differently please let me know.
chrisamitch
- Vehicle: Ford f350 6.7 Diesel
Do you have any information on this process? I am assuming it will be in the PCM module, but could also see where that info could reside in the FICM. I am currently replacing CP4, injectors, and all fuel lines on my 2013 Powerstroke (yep,I did a major bonehead move and now have to pay for my mistakes). I am not to the point of needing to adjust the IQA yet, but any extra info I could gather on the process would make me feel better.
Thanks in advance
Chris
Thanks in advance
Chris
chrisamitch
For everyone trying to adjust their IQA, it is done via the "injection correction factor" portion of the PCM programing. I also had some problems with Forscan giving me an error about the process, but it did accept my new injector IQA codes.
AlTiTuDe6.7
- Vehicle: 2016 f250 6.7 powerstroke
How would I just reset fuel values for current injectors?
