Question and problem
Brianpedroso
Vehicle: Ford Edge SEL 3.5L v6 Ti-VCT 280HP 2018
Post by Brianpedroso »
I would like to know if forscan is compatible with my 2018 Ford Edge SEL 3.5L TIVCT engine and 6F50 transmission.
I use a USB Vgate VLinker FS cable with all the drivers and settings they carry, Windows 11 Home Laptop.
The module updates that it shows as calibrations and strategies are for another car.
My Ford is an MY18 manufactured in June 2018.
The pcm KOER test stops just as if you try to enter the pcm I can only enter the as built , The PCM has no problems, as if I can do the test with a small scanner and my cell phone like the Thindiag.
PCM
Part number:G2GA-12A50-CAA
Calibration level:H2GA-12A650-BJC
Strategy:H2GA-14C204-BJC
Hardware type:FLE3A-12B684-BEA /FLE3A-12B684-BEB
I hope that some administrator or programmer of this software will be able to give an answer for future forscan updates, if you need the VIN let me know, thank you and greetings
