FORScan 2.3.62 on macOS 12.7.6 via Wine 9.0.3
jred
Vehicle: 2021 Ranger 4cyl
Post by jred »
I use FORScan 2.3.62 on macOS 12.7.6 via Wine 9.0.3
Maybe it works as it should. I do seem able to set some PIDs
But the console where Wine starts warns of multiple errors.
Do any of you good folks have experience with these errors?
007c:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
0024:err:environ:init_peb starting L"C:\\Program Files (x86)\\FORScan\\FORScan.exe" in experimental wow64 mode
0058:fixme:mountmgr:harddisk_ioctl Unsupported ioctl 4d004 (device=4 access=3 func=401 method=0)
0024:fixme:winsock:WSALookupServiceBeginA (0012E0F0 0x2 0012E018) Stub!
0104:err:kerberos:kerberos_LsaApInitializePackage no Kerberos support, expect problems
0104:err:winediag:ntlm_check_version ntlm_auth was not found. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0104:err:ntlm:ntlm_LsaApInitializePackage no NTLM support, expect problems
0100:fixme:comm:set_queue_size insize 128 outsize 128 unimplemented stub
0100:err:comm:set_baud_rate baudrate 2000000
