service function not available
Tassie
Vehicle: au falcon ute sflpg 2001
Post by Tassie »
Hi all,
AU Falcon ute 2001, had intermitted no crank issues, interior light not working, door locks not cycling, fuel gauge cycling then stays on empty.
Suspected bcm so replaced bcm and now everything works except engine crank,
trying to reset pats to recode keys and restore communication with bcm but when going to service functions nothing is available to start this function.
Is it not possible with this model?
Any suggestions greatly appreciated.
oldtinfords
Re: service function not available
Post by oldtinfords »
Have a look in Configuration & Programming
boosted_diesel
Post by boosted_diesel »
Tassie wrote: Mon Oct 21, 2024 6:32 am Hi all,
Might wanna check your starter solenoid for functionality and signal and engine ground if you haven’t already for the no crank.
