Ford Focus 2005
ch66ky
Vehicle: AU Ford Falcon,6 cylinder,2001
Ford Focus 2005
Post by ch66ky »
Here is my issue with my 2005 ford focus. any help would be great.. car ran fine just stopped. original code was P2110, have replaced TB with new..
(OK) [14:12:28.262] Key On Engine Off On Demand Self-Test has been started
(WARN) [14:12:39.798] Test completed, found DTCs: P0121, P0122, P0221, P0223, P1549, P1709, P2110
===DTC P0121===
Code: P0121 - Throttle/Pedal Position Sensor A Circuit Range/Performance
The expected voltage output from TP1 at the WOT or the default position is out of range.
Note: This DTC relates to the ETB.
This DTC may be caused by :
An obstruction in the ETB.
TP sensor faulty or damaged
Faulty ETB
===END DTC P0121===
===DTC P0122===
Code: P0122 - Throttle/Pedal Position Sensor A Circuit Low Input
Input to the PCM from TP1 is less than the calibrated limit.
Open or grounded circuit.
Incorrect VREF.
Faulty ETB
===END DTC P0122===
===DTC P0221===
Code: P0221 - Throttle/Pedal Position Switch B Circuit Range/Performance
The expected voltage output from TP2 at the WOT or the default position is out of range.
Faulty ETB
===END DTC P0221===
===DTC P0223===
Code: P0223 - Throttle/Pedal Position Sensor B Circuit High Input
Input to the PCM from TP2 is greater than the calibrated limit.
Signal shorted to VBATT or vref.
Incorrect VREF.
Faulty ETB
===END DTC P0223===
===DTC P1549===
Code: P1549 - Intake Manifold Communication Control Circuit (Bank 1)
IMRC output failed.
Short circuit to ground or battery
PCM driver failure.
===END DTC P1549===
===DTC P1709===
Code: P1709 - PNP Out of Self Test Range
PNP not indicating the desired position during KOEO self-test.
Operator error
Faulty switch operation.
===END DTC P1709===
===DTC P2110===
Code: P2110 - Throttle Actuator Control System - Forced Limited RPM
The system is operating in default mode.
Leaks in air induction system
Faulty ETB
Faulty or damaged PCM.
===END DTC P2110===
boosted_diesel
Re: Ford Focus 2005
Post by boosted_diesel »
Hi there, I’ve seen some of these codes before on a fiesta.
I would start by checking you have what you need at the throttle pedal and the throttle body.
Assuming it’s roughly the same as the fiesta you should find a 6 wire plug on the pedal and also the throttle body.
There should be power/ground signal for each circuit.
Just bear in mind position sensors are often 5v reference but the throttle body actuator circuit is 12v.
If you need any diagrams I might have them on my auto data system. But I would need a few details including make, model, year, engine size, engine code etc to check for diagrams.
Cheers
ch66ky
Re: Ford Focus 2005
Post by ch66ky »
Thanks for the reply, here is the info
Vehicle:
Model: Ford Focus (VIN LFA/LVS/AFA/PE1/FFJ)
Engine: DURATEC-HE / I4
Capacity: 2.0L
Year: 2005
Month: 07
Generation: 2005 MY
Fuel: Gasoline
Transmission gear: Manual
VIN: AFADXXMJDD5A01050
boosted_diesel
Re: Ford Focus 2005
Ok, your car has the same engine as my car lol.
Ill go look up the diagram just now, hopefully it’s in there.
Cheers
boosted_diesel
Re: Ford Focus 2005
Ok there is two different engine codes to choose from on your car.
It is the AODA or AODB?
boosted_diesel
Re: Ford Focus 2005
ch66ky wrote: Sun Jan 19, 2025 12:29 pm Thanks for the reply, here is the info
Vehicle:
Capacity: 2.0L
Year: 2005
Month: 07
Generation: 2005 MY
Fuel: Gasoline
ok im trying to upload the diagram but i keep getting this message when i add the file
"ERROR
Sorry, the board attachment quota has been reached."
maybe i can just email it to you? or pm it
boosted_diesel
Re: Ford Focus 2005
figured it out. diagrams below.
diagram colour coding:
focus 2005 colour code diagram.png (48.64 KiB) Viewed 1353 times
throttle body diagram: the throttle body is A177, motor actuator is M89, throttle position sensor is B169
focus 2005 tb diagram.png (168.54 KiB) Viewed 1353 times
i had to split the throttle pedal diagram into two halves as it wouldnt fit on the screen: B138 is the pedal sensor
top half:
2005 focus pedal pos sensor top half.png (185.24 KiB) Viewed 1353 times
bottom half:
2005 focus pedal pos sensor bottom half.png (200.98 KiB) Viewed 1353 times
ch66ky
Re: Ford Focus 2005
Post by ch66ky »
Thanks for the diagrams, Would also like to know how to recalibrate the throttle, as codes say WOT wide open position. but the throttle is closed.
boosted_diesel
Re: Ford Focus 2005
ch66ky wrote: Sun Jan 19, 2025 10:14 pm Thanks for the diagrams, Would also like to know how to recalibrate the throttle, as codes say WOT wide open position. but the throttle is closed.
Hey, no problem. I think you just reset the pcm learned values.
The live data should show the requested vs the actual position.
So throttle pedal is the requested amount and throttle body is the actual position of the flapper in the body.
The live data may show the pedal sensor is guff. But before writing it off use the diagram to ensure the pedal and body both have all they need to function.
Unfortunately the pedal sensor and the body are common issues.
I’ve even had to replace the plug and pigtail going to a throttle body before because the female pins were mangled by some idiot with a multimeter.
Looking at the codes it could be anything. Even a minor short in the 5v ref brining the voltage down. I think it is saying on one of the codes that when the pedal is at WOT not both sensors agree on that, the voltage reading from one is lower or higher than expected. Check the 5v ref actually has 5v with engine on.
If you need anything else just ask I may have the data or whatever it is.
Cheers
ch66ky
Re: Ford Focus 2005
Post by ch66ky »
Thanks For the Reply Boosted, will check those things. so minor short, will check all the plug harnesses. will get back to you ... cheers..
