2021 Explorer ST Enhanced Memory Retrofit
KazWolfe
Vehicle: 2021 Ford Explorer ST
Post by KazWolfe »
Hi all,
I've been mucking around with programming my 2021 Ford Explorer ST and came across the Enhanced Memory option (not enabled in factory asbuilt). Enabling this setting seemed to work though I came across a (known?) problem where the Ambient Lighting options could no longer be changed. Curiously, everything else regarding Enhanced Memory seemed to actually work on the car - I could register profiles, keyfobs, and the system generally behaved as expected save for a new DTC of U1A00:87-08 in the APIM.
Does anyone know if Enhanced Memory is just a feature toggle, or if it requires extra hardware to work? If the former, is there something I'm missing to preserve ambient lighting and/or deal with the DTC?
Thanks!
KazWolfe
Re: 2021 Explorer ST Enhanced Memory Retrofit
Post by KazWolfe »
Did some more research, and it seems like this is a BCM issue:
Code: Select all
02/22/2025 15:31:57.056/2924/23/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightIntensty_Handler/214/=Previous Value = 0, Current Value = 0
02/22/2025 15:31:57.056/2925/23/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightColor_Handler/257/=lastColordata = 5, AmbColorRspfromServer = 3
02/22/2025 15:31:57.056/3348/1/QT_HMI/[D] ford.al2hmibridge allogger.cpp/101/="DpChg CfgVehicle_AmbientLightColor_E_INT 3"
02/22/2025 15:31:57.116/2926/23/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightIntensty_Handler/214/=Previous Value = 0, Current Value = 101
02/22/2025 15:31:57.116/2927/23/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightColor_Handler/257/=lastColordata = 3, AmbColorRspfromServer = 3
02/22/2025 15:31:57.144/2928/23/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightIntensty_Handler/214/=Previous Value = 0, Current Value = 101
02/22/2025 15:31:57.144/2929/31/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightColor_Handler/308/=Invalid data from dispatcher
02/22/2025 15:31:57.171/3349/1/QT_HMI/[D] ford.al2hmibridge allogger.cpp/101/="DpChg Delay_Acc_Status_E_BOL true"
02/22/2025 15:31:57.170/2930/60/PASA_HMI_IF/static bool BackupIgnition::Delay_Accy_Handler(const UI_8*, UI_32)/691/=BI : DP_ID_Delay_Acc_Status_E_BOL = 1
02/22/2025 15:31:57.171/150/23/VS_CLUSTER_PROXY/EPasStatus CClusterProxyServer::SendNavGuidanceCurrStreetToCluster(void*, NavClusterCurStreetInfo&)/5037/=Sending current streetname as [See Touch Screen] , Speed limit : [0]
02/22/2025 15:31:57.176/2931/23/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightIntensty_Handler/214/=Previous Value = 0, Current Value = 0
02/22/2025 15:31:57.176/2932/31/PASA_HMI_IF/Veh_LanguageSettingsAmbientLightColor_Handler/308/=Invalid data from dispatcher
I can't, however, find any more information on the BCM side of things. The BCM itself is also set to use Enhanced Memory, so it's a bit curious. Perhaps there are in fact hardware requirements?
