asbuilt
grousebeater
Vehicle: Ford Kuga 2016 Zetec diesel 150bhp awd.
asbuilt
Post by grousebeater »
Hi guys after a problem with severe battery drain and a broken wire to the sync 1 system on my Ford Kuga mk2 2016 2 ltre diesel I repaired wire fitted new battery old battery was from 6/2016 I have lost comunications codes will taking it back using asbuilt code help or brick my car.
===DDM DTC None===
Successful DTC reading, no error codes found
Module: Drivers Door Module
===END DDM DTC None===
===HVAC DTC U0155:00-28===
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Status (-28):
Module: Heating Ventilation Air Conditioning
===END HVAC DTC U0155:00-28===
===RFA DTC None===
Module: Remote Function Actuator
===END RFA DTC None===
===ACM DTC B1D55:15-28===
Code: B1D55 - Antenna #2
Additional Fault Symptom (:15):
- Circuit Short To Battery Or Open
Status (-28):
Module: Audio Control Module
Freeze Frame #1:
-EVENT_TIME: 410550995 s - Event time
-TOTAL_DISTANCE: 274891 km - Total Distance
-MODULE_VOLTAGE: 12.3 V - Control Module Voltage
-INCAR_TEMPERATURE: 23 °C - In car temperature
===END ACM DTC B1D55:15-28===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
Thanks for any help for this Forscan virgin.
boosted_diesel
Re: asbuilt
Post by boosted_diesel »
Those codes appear to be not present, have you tried just deleting them?
grousebeater
Re: asbuilt
Hi thanks for the reply yes tried to clear them I posted in a rush I have just noticed it has not copied the full dtc here is the full list.
===PCM DTC None===
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===SASM DTC None===
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RCM DTC U0140:00-28===
Code: U0140 - Lost Communication With Body Control Module
Status (-28):
===END RCM DTC U0140:00-28===
===RCM DTC U0415:00-28===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module 'A'
Status (-28):
===END RCM DTC U0415:00-28===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===BCMii DTC B10D7:51-6C===
Code: B10D7 - PATS Key
Additional Fault Symptom (:51):
- Not Programmed
Status (-6C):
- DTC Maturing - Intermittent at Time of Request
- Test not complete
Module: Body Control Module
Freeze Frame #1:
-EVENT_TIME: 410491046 s (Sun Dec 17 18:36:15 2023) - Event time
-TOTAL_DISTANCE: 274874 km - Total Distance
===END BCMii DTC B10D7:51-6C===
===BCMii DTC B112B:07-28===
Code: B112B - Steering Wheel Module
Additional Fault Symptom (:07):
- Mechanical Failures
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 410490751 s (Sun Dec 17 18:31:20 2023) - Event time
-MODULE_VOLTAGE: 12.0 V - Control Module Voltage
===END BCMii DTC B112B:07-28===
===BCMii DTC U0155:00-28===
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 410544107 s (Mon Dec 18 09:20:36 2023) - Event time
-MODULE_VOLTAGE: 14.8 V - Control Module Voltage
-INCAR_TEMPERATURE: 117 °C - In car temperature
===END BCMii DTC U0155:00-28===
===BCMii DTC B10EF:12-6C===
Code: B10EF - Sunroof Speed Output
Additional Fault Symptom (:12):
Status (-6C):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 410542994 s (Mon Dec 18 09:02:03 2023) - Event time
-INCAR_TEMPERATURE: 80 °C - In car temperature
===END BCMii DTC B10EF:12-6C===
===BCMii DTC B10EF:14-6C===
Additional Fault Symptom (:14):
- Circuit Short To Ground Or Open
Status (-6C):
- Test not complete
Freeze Frame #1:
===END BCMii DTC B10EF:14-6C===
===FCDIM DTC U0140:00-2E===
Status (-2E):
Module: Front Control/Display Interface Module
===END FCDIM DTC U0140:00-2E===
===SRM DTC None===
Module: Speech Recognition Module
===END SRM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC None===
Status (-28):
===RFA DTC None===
Status (-28):
Freeze Frame #1:
===IPC DTC None===
Hope you can help me thanks Ken
boosted_diesel
Re: asbuilt
Yeah that’s a lot of codes. I see many are communication codes for what are probably can bus modules. You may wanna do some basic network tests to check the network is all there and has no interference. How much you can test will depend on what equipment you have. I think FORScan can probably do some basic network test. You can also check for newtwork integrity using a multimeter set to ohms, connect your meter probes to pins 6 and 14 of the obd port, those are can high and low, you should find 60 ohms between those pins. Higher or lower resistance would tell us a lot. If you have an obd breakout box and a scope then scope the network and check the signal looks good. I would start there as it should only take a short time.
martin123
Vehicle: transit connect 2003 1.8 tddi
Re: asbuilt
Post by martin123 »
Would testing resistance on pins 6&14 on a 2013 transit work the same?
My friends transit has abs data invalid to pcm
boosted_diesel
Re: asbuilt
martin123 wrote: Wed Feb 19, 2025 3:03 pm Would testing resistance on pins 6&14 on a 2013 transit work the same?
Yeah 6 is can high and 14 is can low on obd2. There are two 120 ohm terminating resistors one at each end of the network. If all wires are connected properly end to end then you should find 60 ohms between those pins.
