[Guide] Unlock Sport Mode in Ford Fiesta MK8 1.5 TDCi
Posted: Wed Feb 19, 2025 10:14 am
Foreword
It's superfluous to point out that any damage resulting from this modification is only your responsibility!
After months of searching, banging my head without finding anything useful and always getting the same message from everyone “It's impossible” here I am.
Today I announce that I finally managed to unlock the Sport driving mode on Ford Fiesta MK8 with 1.5 TDCi engine without Canbus Box or any other tricks.
Below the guide and prerequisites:
Prerequisites
The drive mode selection panel must be as in the following picture:
and NOT:
Consider that if production year of your car is < of late 2019 it's very likely that you will not be able to unlock this and other modes unless you upgrade/replace all the modules needed to change modes (PCM, ABS, PSCM, HVAC and most likely others).
In summary you must have at least GEN2.
Guide
You simply need to edit the first two bytes in third block in register 760-03-03 in ABS module and the possible configurations available are as follows:
- For the first byte
In addition, my hardware configuration with related P/Ns, strategies, calibrations, etc...
Anyway, my current configuration is:
760-03-03 -> XXXX-XXXX-2B
That enables Eco, Normal, Sport and Slippery modes.
In case of any DTCs (in my case in PCM, ABS, RCM and IMPA), you can delete them, they are temporary DTCs caused when writing the new configuration in ABS module and will not appear again.
I have not yet had a chance to thoroughly test how well this new configuration works, but I would say that it's a good place to start to finally be able to change select drive modes for real and without any adapters or tricks.
And finally...
Prerequisites
and NOT:
Guide
- For the second byte0=SGM8 Disabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Disabled, SGM5 Disabled
1=SGM8 Disabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Disabled, SGM5 Enabled
2=SGM8 Disabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Enabled, SGM5 Disabled
3=SGM8 Disabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Enabled, SGM5 Enabled
4=SGM8 Disabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Disabled, SGM5 Disabled
5=SGM8 Disabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Disabled, SGM5 Enabled
6=SGM8 Disabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Enabled, SGM5 Disabled
7=SGM8 Disabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Enabled, SGM5 Enabled
8=SGM8 Enabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Disabled, SGM5 Disabled
9=SGM8 Enabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Disabled, SGM5 Enabled
A=SGM8 Enabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Enabled, SGM5 Disabled
B=SGM8 Enabled, SGM7 Tow/Haul Mode Disabled, SGM6 Low Mu Mode Enabled, SGM5 Enabled
C=SGM8 Enabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Disabled, SGM5 Disabled
D=SGM8 Enabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Disabled, SGM5 Enabled
E=SGM8 Enabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Enabled, SGM5 Disabled
F=SGM8 Enabled, SGM7 Tow/Haul Mode Enabled, SGM6 Low Mu Mode Enabled, SGM5 Enabled
I got the information about the possible configurations available from Cyanlabs DB Asbuilt website.0=SGM4 Economy Mode Disabled, SGM3 mode Disabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Disabled
1=SGM4 Economy Mode Disabled, SGM3 mode Disabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Enabled
2=SGM4 Economy Mode Disabled, SGM3 mode Disabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Disabled
3=SGM4 Economy Mode Disabled, SGM3 mode Disabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Enabled
4=SGM4 Economy Mode Disabled, SGM3 mode Enabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Disabled
5=SGM4 Economy Mode Disabled, SGM3 mode Enabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Enabled
6=SGM4 Economy Mode Disabled, SGM3 mode Enabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Disabled
7=SGM4 Economy Mode Disabled, SGM3 mode Enabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Enabled
8=SGM4 Economy Mode Enabled, SGM3 mode Disabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Disabled
9=SGM4 Economy Mode Enabled, SGM3 mode Disabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Enabled
A=SGM4 Economy Mode Enabled, SGM3 mode Disabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Disabled
B=SGM4 Economy Mode Enabled, SGM3 mode Disabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Enabled
C=SGM4 Economy Mode Enabled, SGM3 mode Enabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Disabled
D=SGM4 Economy Mode Enabled, SGM3 mode Enabled, SGM2 Sport Mode Disabled, SGM1 Normal Mode Enabled
E=SGM4 Economy Mode Enabled, SGM3 mode Enabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Disabled
F=SGM4 Economy Mode Enabled, SGM3 mode Enabled, SGM2 Sport Mode Enabled, SGM1 Normal Mode Enabled
And apart from ACM, APIM, IPC and IPMA the rest of the modules remained unchanged, I only updated PCM firmware and BdyCM firmware but for other reasons.Veicolo:
Modello: Ford Fiesta
Motore: Duratorq Turbo Diesel Common Rail Injection
Cilindrata: 1.5L
Anno: 2019
mese: 12
Generazione: 2017 MY
Carburante: Diesel
Trasmissione: Manuale
SYNC version: SYNC 3
PCM - Modulo gestione motore
Part number: J1B1-12A650-TA
Calibration level: L1B1-12A650-ML
Strategia : L1B1-14C204-ML
Hardware type: HA6A-12B684-MA
APIM - Modulo interfaccia protocollo accessori
Part number: LU5T-14G371-GNC
Calibration level: NU5T-14G371-GAJ
Strategia : 1U5T-14G374-EM
Calibrazione: 1U5T-14G375-HA
PAM - Modulo ausilio parcheggio
Part number: HU5T-15K866-AG
Calibration level: HU5T-15K866-AG
Strategia : HU5T-14C090-AG
BdyCM - Modulo di comando carrozzeria
Part number: LU5T-14B476-BCD
Calibration level: LU5T-14B476-BJC
Strategia : LU5T-14C184-ACH
ABS - Sistema frenante antibloccaggio
Part number: L1BC-2C219-AC
Calibration level: L1BC-2C219-AC
Strategia : L1BC-2D053-AC
TCU - Centralina telematica
Part number: LR3T-14G087-VE
Calibration level: LR3T-14G087-VM (latest known: LR3T-14G087-VR)
Strategia : LB5T-14G139-SM
PDM - Unità di comando portiera lato passeggero
Part number: LU5T-14B533-AC
Calibration level: LU5T-14B533-AC
Strategia : LU5T-14C108-AC
DDM - Modulo portiera guidatore
Part number: LU5T-14B531-AC
Calibration level: LU5T-14B531-AC
Strategia : LU5T-14C064-AC
RCM - Modulo di controllo sicurezza passeggeri
Part number: H1BT-14B321-AJ
Calibration level: H1BT-14B321-AJ
Strategia : L1TT-14C028-AA
Calibrazione: H1BT-14C098-AH
HVAC - Riscaldamento, ventilazione e aria condizionata
Part number: H1BT-18C612-AK
Calibration level: H1BT-18C612-AK
Strategia : GN15-18D619-AK
PSCM - Power Steering Control Module
Part number: H1BC-3F964-AJ
Calibration level: H1BC-3F964-AJ (latest known: H1BC-3F964-AK)
Strategia : K1BC-14D003-AE
ACM - Modulo di comando audio
Part number: H1BT-18C815-HN
Calibration level: H1BT-18C815-HN (latest known: H1BT-18C815-HV)
Strategia : H1BT-14C044-HXM
Calibrazione: H1BT-14C045-HE
SCCM - Steering Column Control Module
Part number: H1BT-3F944-AJ
Calibration level: H1BT-3F944-AJ
Strategia : GN15-14C579-AJ
IPC - Quadro strumenti del cruscotto
Part number: L1TT-10849-FBL
Calibration level: L1TT-10849-FBL
Strategia : L1TT-14C026-FCD
Calibrazione: L1TT-14C088-FCD
GWM - Modulo gateway A
Part number: K1BT-14F642-BC
Calibration level: K1BT-14F642-BC
Strategia : K1BT-14F530-BC
IPMA - Modulo elaborazione immagini A
Part number: H1BT-19H406-CE
Calibration level: H1BT-19H406-CE
Strategia : H1BT-14F397-AE
Calibrazione: H1BT-14F398-AE
And finally...
