I have a 2019 Ford Ranger 2.0L TDCI Ecoblue
I recently replaced my high-pressure fuel pump due to a defective PCV.
Before replacing the pump I was getting "P0087 - Fuel Rail/System Pressure - Too Low Bank 1" whenever the engine is on load and the rpm exceeds 3500.
After replacing the high-pressure pump, I am now getting the following DTC when the engine is on load and the RPM exceeds 3500.
Code: P228D - Fuel Pressure Regulator 'A' Exceeded Control Limits - Pressure Too High
I have read a few posts here and I've seen some recommendations to carry out some relearn procedures, however, those options are not available in my Forscan.
I would appreciate any help on this issue.
PCM DTC P228D:00-68 Ford Ranger
KennySamaroo
- Vehicle: 2019 Ford Ranger 2.0L Ecoblue Diesel
KennySamaroo
Re: PCM DTC P228D:00-68 Ford Ranger
Can anyone help with this?
@Forscan?
@Forscan?
