I have an Airbag light on a 2012 Ford Edge. When I run ForScan, I am not seeing the RCM listed as one of the available modules.
I would expect that is there is an issue with the RCM, I would see a non-coms code of some sort?
2012 Ford Edge Airbag Light (RCM)
ifrythings
- Vehicle: Ford F-350 6.4L 2008
Re: 2012 Ford Edge Airbag Light (RCM)
If the RCM isn’t talking on the bus for whatever reason you will get other modules (ABS, IPc, PCM) having codes for lost coms from the RCM. If you don’t have any modules complaining about missing the RCM then I would start with what adapter are you using? Is it up to date on firmware?
Thanks for the response.
I am using the OBDLink EX FORScan OBD Adapter. I'll have to check the firmware, but it was just purchased this past December. So I wouldnt think it would be too far out of date.
No other modules were complaining about lost COMS. But I'll see if I can hook up to it later on and post some logs.
