Force a DPF regeneration on S-Max
Hello, I have a Ford S-Max 2010 2l 103kW and the turbo pipe was broken and now the dpf is fully clogged with soot. I tried to force a regeneration but it's not possible anymore because it's already too clogged. I cleared dpf values and tried again, but still a warning message "dpf too full replace dpf". Is there any way to force the dpf regeneration when soot mass is too high?
Re: Force a DPF regeneration on S-Max
It does not start regeneration because of the dpf fault codes in pcm. That's why I read the software from pcm with a flashtool, killed all dpf related fault codes, flashed software back. Without fault codes I could force the regeneration. DO NOT DO THIS!
