PSCM "locked" with dtc u3000
olenylende
Vehicle: Mondeo 1.5 ecoboost 160hp 2017
Post by olenylende »
Hi all, my first post here
Got some problems with our car earlier this week, happended suddenly with no indications before.
Basically the pscm went into u3000 in a roundabout and threw codes C200D-49 and U3000-49.
So I started research and found this forum/software.
I started reading on how to update the firmware and did that last night, there was only one version for it and no never version.
So i tried to force write but did not change anything.
Does anyone have any tips to get the module out of U3000? From what i found the firmware is basically "locked" and
no ordinary scanner/tool etc will be able to delete the code. I have found some info on MHH but i think they unsolder the eprom to
read it in a chip burner and then put it back with modified/cleared firmware.
I was hoping to get it out of the U3000 to see if what i have done to it has fixed the problem.
Anyone got a tip or solution?
DAN1000
Vehicle: Maverick 2.0 2025
Re: PSCM "locked" with dtc u3000
Post by DAN1000 »
U3000 is the CPU's message to you that its damaged
Dont think you can program your way out of it
