ID TPMS
darwin77
Vehicle: focus, 2000,2012
ID TPMS
Post by darwin77 »
Does anyone know how to change the TPMS IDs to replace them? I can't find the function in Forscan. I would like to know if it's possible. I have the OBDLink EX USB adapter. Please, if anyone knows how to do it, share the information with me.
DBMoehl
Vehicle: F150 gas 5.0L 2011
Re: ID TPMS
Post by DBMoehl »
I am facing the same issue:
2011 F150 XLT Scab 5L 4x4; FORScan v2.3.70; OBDLINK-EX USB adaptor with firmware updated on 02/01/2026
I can see the four TPM_RFR_(nn) values using the oscilloscope - (monitor) icon but I don't see any way to edit these HEX values using the Chip (Configuration) icon to the ID numbers I read using my Launch CRT5011E TPMS tool.
I've used the Ford Owner Manual training/relearn procedure to train a set of new MoreSensor Compact PRO (preprogrammed) sensors with my Launch TPMS tool.
I've also trained a set of used stock Ford 2014 (315 MHz) sensors to my truck.
I can read the IDs of the sensors in a set of used 2018 Ford wheels (315 MHz), but the Ford training/relearn will not write them to the BdyCM or IPC...
I've disabled the TPMS for now...
Any insight would be appreciated.
