Latest Beta Version
Latest Beta Version
I’m needing to program a TCM in a 2013 Ford focus and therefore need to use the beta version of forscan. How may I download the latest beta version of forscan? I already have the file I need to program the TCM with
Re: Latest Beta Version
If you are a Paid FORScan license holder and you are a logged in member of this Forum you should have Access to the Private beta Test section(Beta Testing-private) of this forum(should be in a Forum thread right below this Beta Test thread section)!gabewall wrote: Wed May 21, 2025 9:28 pm I’m needing to program a TCM in a 2013 Ford focus and therefore need to use the beta version of forscan. How may I download the latest beta version of forscan? I already have the file I need to program the TCM with
Paid license holders should have received a 'Forum Invitation Code" along with the License activation in the Email/Invoice that allows paid license holders to access the Private Beta test section! Should be a string of Upper case letters!
The 2.4.xx beta will only work for your intended purpose, if the laptop/computer has a valid paid FORScan license activation!
At the Bottom of the First Post in the Private Thread under "Announcements" which should currently be Headed as "FORScan v2.4.18 beta" is where the down link should be found!
If you are not logged in or did not receive and input the the invitation code upon joining this forum the Private thread will not be visible!
