A/C not work on Ford Custom 2018
victor2k
Vehicle: Yaris,gasoline,998 cm3,2004
Post by victor2k »
I have in workshop a 2018 Ford Custom with nonworking AC(AC_DMND is off in PCM data list evenif is on or off on HVAC).The pressure is ok(aprox 600KPa),no faults in HVAC but a lot of strange faults in PCM related to transmission even the car is equipped with manual transmission.I think PCM was rewrited ,not sure if as-built was corruped or not.
Please look at my attached files,any advice is wellcome.
Thank you
CJ18CPL.txt
(8.39 KiB) Downloaded 26 times
CJ18CPL.fsl
(14.79 KiB) Downloaded 20 times
WF0YXXTTGYJP85306_PCM_20250617_092523.rar
(1.06 KiB) Downloaded 25 times
DAN1000
Vehicle: Maverick 2.0 2025
Re: A/C not work on Ford Custom 2018
Post by DAN1000 »
You have low battery codes, try clearing codes & see what comes back
victor2k
Post by victor2k »
After clearing the fault codes related to low battery was not stored again.
Solved,my problem was fusebox with no contact on f28.
Best regards
