Ford Transit 2.0tdci 2018y communication problem
bathon791
Vehicle: mondeo 2.0 tdci 140ps 2007y
Post by bathon791 »
Hello respected group. Maybe someone has encountered this issue and can help. I received a 2018 Transit with no communication from some subsystems – though I'm not entirely sure which ones, as I can only communicate with the PCM and BCM, not the others. I found a CAN wiring diagram in Autodata, but not everything matches the diagram, and I'm stuck with the diagnostics. The BCM shows errors indicating no communication with the cluster. I checked the CAN lines and they seem fine in terms of continuity. I’ll add that the vehicle starts and drives, but there's no speed information from the ABS – this shows up in the PCM. Maybe someone has had a similar case and can help, or has a proper wiring diagram for this vehicle. Thank you in advance for your help.
