Remote Function Actuator programming
NenAutowork
Vehicle: FIESTA,1.6,2010
Post by NenAutowork »
hello any one done it before? to program RFA module or Remote Function Actuator? because the vehicle is not going IGnition ON when replacing RFA, forscan cant detect module when ignition is OFF, anyone can help me? Ford ECOSPORT 1.6 2018 :D :roll:
boosted_diesel
Re: Remote Function Actuator programming
Post by boosted_diesel »
hi there, to get the ignition on, hold the fob up to the column or whichever point the manual describes for emergency starting, this will put the ignition on if the fob is programmed to the car. you can then program new rfa madule with forscan.
cheers
