I've got a 2025 F150 Reg Cab Short Bed with the 5.0.
I've got the OBDLink EX USB cable
Any changes I make, I write them and then power cycle the truck, the changes never take effect.
I've tried making changes in multiple modules, but I get the same results.
Changes show in ForScan but not on the truck.
For example, if I disable SeatBelt Chimes for Driver and or Passenger and write the changes, after power cycling the truck the changes never take effect.
Additionally if I try to change the splash screen to the GT and I power cycle the truck and then reboot the APIM module the changes never take effect.
I'm running the latest version of the app. I've tried the simple version and the as built and I get the same results.
This has to be something simple that I'm missing.
Any help would be greatly appreciated,
Thanks,
Changes not commiting after writes..
Re: Changes not commiting after writes..
Is there a paid support option to get the help I need?
Whatever I'm doing wrong has to be something minor and I bet I feel like an idiot after learning what it is.
But there are many changes I would like to make and this is holding me up..
My son just also bought a 2025 F150 like mine and would like changes as well but he's scared to even try until we get this sorted.
Don Ridley
If you have a paid license, you can contact Forscan support. See the website for contact information and instructions. Forscan does not always monitor the forum.
You can also check the various F150 forums. They have the Forscan experts that created the spreadsheets. They will also know if the 2025s have been fully implemented in Forscan (it takes time to do this for every new model).
The Paid license Support with the email address and the debug instructions are at the heading "Providing FORScan Debug Information" and describes what files and where they are on your computer that The Team wants you to send them, can be found at this link: https://forscan.org/contactus.html!jcs725 wrote: Mon Sep 01, 2025 6:16 pm Is there a paid support option to get the help I need?
Thank you for this. I sent the zip file and a description of the issue.. Hopefully they can assist.
5thibaults
- Vehicle: fusion 2.0 2018
Did you find a solution? I’m having the same problem.
