Transit custom 2019.75MY - PATS distributed - No"module initialization" option
Posted: Mon Sep 01, 2025 4:26 pm
I have a Ford Transit Custom 2019.75MY 2.0 EcoBlue (Duratorq) with PATS distributed (BCM + PCM + ABS).
Forscan (v2.4.18 beta, Extended License) detects my keys correctly (2 keys stored), but the van does not start (immobilizer active, key light stays solid).
Problem:
In the BCMii PATS menu, I only see the following options:
Show distributed PATS scheme
Program ignition key
Erase and program keys
Initialize steering column lock
Spare keys programmable (disabled)
But I do not see the option “Module Initialization (BCM–PCM)” which is required to re-synchronize BCM and PCM in the distributed PATS system.
Setup:
Interface: vLinker FS USB (recommended adapter)
Forscan version: 2.4.18 beta
Extended License active until 2025
Modules detected: PCM, BCMii, ABS all present
Could you please provide a newer test build (2.4.19 or higher) that enables the PATS Module Initialization option for this vehicle?
Thank you very much!
Problem:
Setup:
