2005 f 150 tried to do pcm firmware update fail !!!!
alphaomega2025
Vehicle: 2018 ford explorer 3.5
Post by alphaomega2025 »
i tried to perform firmware update pcm when i started to dowload the file it did stoped at 3% i was using maxi vci v200 autel
oldtinfords
Re: 2005 f 150 tried to do pcm firmware update fail !!!!
Post by oldtinfords »
alphaomega2025 wrote: Fri Sep 12, 2025 12:11 am i tried to perform firmware update pcm when i started to dowload the file it did stoped at 3% i was using maxi vci v200 autel
What stopped?
The file download or programming?
Does the device support 18v FEPS programming?
Are you using the latest 2.4.18beta? If not, install it. Make sure you have an internet connection to download the required files.
Your PAID licence also needs to be curren to download the files.
Screenshots of the programming screen & log are extremely helpful. Make sure to attach them.
Also make sure there's a charger on the vehicle & laptop to avoid programming failures. Low voltages are going to cause you dramass
