No Adapter Found error message
I am trying to connect to my '07 Explorer with FORS using the Vlinker ELM327 HS/MS CAN AUTO SWITCH adapter. At first, I was told that my version of FORScan needed updated which I did and also installed the required usb driver again (using Windows 10). I also had to renew my subscription and validated it with the new auth code. I had previously used the same laptop and ELM327 on the same vehicle with no problems. Now, I keep getting the error message telling me "No Adapter Found. Check connections....." I have retried connecting several times, even resorting to the original ELM327 manual switching adapter, still with no results. What am I doing wrong? PLEASE HELP ME!!
Saving Eddie Bauer Explorers, one at a time
