Using differing forscan versions on 1 machine
HOT CLUTCH
Vehicle: 2013 focus st, 1966 gt350, 78 bronco
Post by HOT CLUTCH »
Is it possible to have two differing versions of forscan on one machine?
I would like to be able to install and use version 2.3.67 and the latest beta version on the same machine. As it's a beta version having a known good working version residing on the same machine is desirable.
Do I need to pick one or the other?
boosted_diesel
Re: Using differing forscan versions on 1 machine
Post by boosted_diesel »
Essentially yes you'll hve to pick one or the other. I tried the same and it just over writes the current installation.
The only option to make it work would be dual operating systems which I have done on an old laptop for this.
oldtinfords
Post by oldtinfords »
HOT CLUTCH wrote: Sat Nov 08, 2025 3:04 pm Is it possible to have two differing versions of forscan on one machine?
Just use the beta. I've been using it since the very early days & haven't had any problems. There are functions I use regularly that aren't available in the 2.3.** versions
