Unable to program shift strategy code
SilentzHero
Vehicle: 2010 Ford fusion 2.5
Post by SilentzHero »
2010 ford fusion just replaced valve body
forscan 2.4 obdlinkex
(OK) [18:26:21.645] PCM Transmission Characterization Update has been started
(OK) [18:26:22.495] Transmission: 6F FWD, Current solenoid strategy number: 0991021569748, Current solenoid body ID: 12447BC
(WARN) [18:26:38.813] Loading file 1635127252811.6F...
(ERR) [18:26:38.821] Unable to rewrite TRID block
(OK) [18:26:43.811] Service procedure completed successfully.
(OK) [18:26:47.540] PCM Module firmware update has been started
(WARN) [18:26:47.551] Reading vehicle info...
(WARN) [18:26:48.062] Unable to read current firmware p/n, use assembly p/n: 9E5A-14D584-AB
(WARN) [18:26:48.632] Redirect from the function Transmission Characterization Update...
(WARN) [18:27:01.665] Total size: 1.93 Mb. Estimated duration: 3m - 5m
(OK) [18:27:04.540] FEPS programming signal has been applied
(ERR) [18:27:35.003] Unable to gain access: The vehicle conditions are incorrect
(ERR) [18:27:35.259] Service procedure has been interrupted
keeps giving me trid block error than redircting to updadte pcm module firmware and then fails to update firmware, what do I do from here?
Joh150413
Vehicle: Taurus,3.5 Ecoboost, 2016
Re: Unable to program shift strategy code
Post by Joh150413 »
Needs the 18v FEPS signal to program PCM. obdlink ex cannot supply 18v signal. Get a vLinker FS which will supply 18v signal.
https://www.amazon.com/vLinker-USB-Prog ... B0CZ92SLDY?
