TPMS relearn option missing?
theo_de
Vehicle: Fiesta ST 180, 2015
Post by theo_de »
Hi there,
I'm trying to fix a hickup with tpms by doing a relearn of the sensors. The only problem is that the manual way of entering relearn (press brake, release brake, push button until chime, ... ) is not working at all. I found some posts all over the internet saying that forscan has a service procedure to enter that mode, but I'm unable to find it in the software. I am usually good with computers, but even after going through all available service functions and configuration menus I can't find it.
Is that function not available for all cars or are there maybe other conditions? Any pointers would be greatly appreciated!
FORscan v2.3.66 full license with vLinker FSv2 USB-cable
Car is a 2015 Ford Fiesta ST european model
TIA,
Theo
boosted_diesel
Re: TPMS relearn option missing?
Post by boosted_diesel »
Hi, I would check your sensors work correctly first.
theo_de
Post by theo_de »
the sensors work fine I have a tool that can read them. This doesn't help much about the missing option in forscan though ... ;)
boosted_diesel
Well it does if your endgame is to make it work.
If one of the sensors doesn't work then it won't relearn anything pal.
theo_de
Post by theo_de »
Right. But they work. I just can't enter relearn by the enduser procedure and can't find the place in FORscan to do it. And that is the thing I asked for help about.
I appreciate the reminder to look for other problems about tpms, but most of that has been checked already. I honestly just want to press a button to start the relearn procedure and get it done ...
boosted_diesel
Well good luck with that
