Hey I bought a new Exide EA612 battery for my MK7 Fiesta. Its 61 Ah and 600 CCA wet battery, no EFB or AGM.
What battery do I choose from the drop down menu?
Also I've already reset the BMS do I have to reset again?
Thanks.
Which type of battery to code
boosted_diesel
Re: Which type of battery to code
New battery needs to be the same type as the oldish less you can change the type in bms. You choose the type that matches what you have. If there is no match it's the wrong battery type.
