zf6hp26 reset issues
jai1988
Vehicle: 2011 ford fg xr6t sedan zf6hp26
Post by jai1988 »
Hi people I get an issue with Forscan using Vlinker fs usb everything is on the latest update. When I try to clear zf adaptive tables I get the vehicle conditions are incorrect service procedure failed. Is there some thing I may be missing is the Vlinker capable of this procedure. the vehicle is a 2011 ford falcon xr6 turbo sedan with the zf6hp26 transmission.
oldtinfords
Re: zf6hp26 reset issues
Post by oldtinfords »
jai1988 wrote: Sat Dec 06, 2025 12:06 am Hi people I get an issue with Forscan using Vlinker fs usb everything is on the latest update. When I try to clear zf adaptive tables I get the vehicle conditions are incorrect service procedure failed. Is there some thing I may be missing is the Vlinker capable of this procedure. the vehicle is a 2011 ford falcon xr6 turbo sedan with the zf6hp26 transmission.
FORScan can't clear the adaptations & the process required is something that is only accessible using specialised tools. It can be done with the workshop version of PCMtec or with the TesterPresent Ford ZF 6HP26 Toolkit. Lots of workshops have been buying the TesterPresent software.
https://testerpresent.com.au/software.html
Either software will need a J2534 device eg https://obdxpro.com/product/obdx-pro-fx ... nd-tuning/
The OBDX ProFT also supports Ford PCM programming
Add your location. There are a few people around who have the software that can reset the adaptations. I might be able to point you in the right direction to get it done if you don't want to spend money buying the J2534 device & software.
jai1988
Post by jai1988 »
Thanks for the info mate I have a tuner that is local to me that tunes using pcmtec so I assume he would be able to reset it for me.
oldtinfords
jai1988 wrote: Fri Dec 12, 2025 12:07 am Thanks for the info mate I have a tuner that is local to me that tunes using pcmtec so I assume he would be able to reset it for me.
If he has the full workshop version, he should be able to do it if he has worked out how it's done. If he hasn't already licenced your car, it could cost you $4-500. That's what I've seen a few tuners charge for TCM adaptation resets
