Hi. I have a 2021 Mustang 2.3 with the 201A package. I’m very new to FORScan. I’m connected and able to make changes—I changed my splash screen as a test.
My real issue: the backup camera had a poor image when I bought the car, so I installed a new OEM camera from Ford. The image is better, but the backup guidelines are gone. There are no Sync 3 settings to enable or disable them; they should just appear.
I’ve checked the configuration and programming sections in FORScan but don’t see an obvious place to start. I have no experience with “as-built” data, charts, or values, so I’m hoping this can be enabled through the normal configuration options.
Any help would be appreciated, and pardon my lack of terminology.
New reverse camera, Guide lines gone
blunderbuss
- Vehicle: Mustang, Ecoboost 2.3,310,2021
Re: New reverse camera, Guide lines gone
do a LIN reset
helped me on Edge run module installation
then the lines came back
