Security access for focus blocked after many attempts to program modules to flood damaged focus,how do i resolve this.
Thanks for a great tool.
security access blocked
patmotorcare
- Vehicle: mondeo tdci 2014
- Vehicle: *** Ford ***
Re: security access blocked
patmotorcare wrote: Mon Dec 08, 2025 8:52 pm Security access for focus blocked after many attempts to program modules to flood damaged focus,how do i resolve this.
https://www.google.com/search?q=Forsca ... &ie=UTF-8
patmotorcare
Thanks for your reply but forscan has blocked access saying too many modules programmed..suspect illegal use.contact forscan.
Without a Model year and some more information like Paid License or Trial Licence status, I can only speculate that you have run Paid online(Out-code In-code) license PATS key programming on two separate vehicle VIN numbers and that is the limit for one license! Purchasing another license will allow two more PATS programming on separate VIN sessions!patmotorcare wrote: Tue Dec 09, 2025 10:26 am Thanks for your reply but forscan has blocked access saying too many modules programmed..suspect illegal use.contact forscan.
Screen shots of your log would help as well as the exact error message from FORScan!
I have never seen a limit to module programming nor have I aver seen that message in any of the module programming I have done!
PATS programming as far as I am aware is to only process that is limited to two vehicle VIN's per Paid license!
Contact FORScan using the instructions here: https://forscan.org/contactus.html#debug_info
