does the type of scanner being used determine which modules you can access?
hello everyone, i have the ELM327 scanner, and im trying to put my 2020 escape 1.5L into brake maintenance mode. but for the life of me i cant find the EPB module. what am i doing wrong? or not seeing? any help will be greatly appreciated!!! thanks
Re: does the type of scanner being used determine which modules you can access?
There isn't normally an EPB module, you access what you want to do under service procedures.
FORScan may not work properly unless you use one of the recommended adaptors.
