does the type of scanner being used determine which modules you can access?
Posted: Tue Dec 23, 2025 4:55 am
by dannyh113
hello everyone, i have the ELM327 scanner, and im trying to put my 2020 escape 1.5L into brake maintenance mode. but for the life of me i cant find the EPB module. what am i doing wrong? or not seeing? any help will be greatly appreciated!!! thanks
Re: does the type of scanner being used determine which modules you can access?
Posted: Tue Dec 23, 2025 7:13 am
by Donny
There isn't normally an EPB module, you access what you want to do under service procedures.
FORScan may not work properly unless you use one of the recommended adaptors.
