hi,
i own ford fusion 2015 2.0 240km. i wanted to add 2nd my key. since i bought this car in Poland (originally came from USA or Canada) and i own currently only 1 mykey. bought 2nd key from Ali with 902Mhz. the numbers from mykey were similar to what i have on 1st (original mykey).
when enterring Forscan->PATS i receive an error "unexpected answer from Forscan server.." and "procedure canceled". can you explain me what i'm doing wrong?
PATS
hueypilot
- Vehicle: 2017 Ford Police 3.5L
Re: PATS
If you anticipate utilizing Passive Anti-Theft System (PATS) functionality (programing keys/parameter reset or module initialization) on any of the vehicles listed below, you are required to be to an automotive security professional that is registered with the National Automotive Service Task Force (NASTF) Vehicle Security Registry. For help with your vehicle security credential please contact the NASTF Vehicle Security Professional help desk at 810-289-4809 or email support@nastf.org.
You MUST provide a valid Vehicle Security Credential (VSC) Id and Passcode when using PATS after purchasing the subscription.
Starting Model Year:
2013
Fusion, MKZ
2015
F-150, Edge, Mustang, MKC, Focus, Focus BEV
2016
Explorer, MKX, C-Max
2017
Ford GT, Continental, F-Series Super Duty, Escape
2013
Fusion, MKZ
2015
2016
2017
Re: PATS
FYIhueypilot wrote: Tue Jan 20, 2026 1:56 am If you anticipate utilizing Passive Anti-Theft System (PATS) functionality (programing keys/parameter reset or module initialization) on any of the vehicles listed below, you are required to be to an automotive security professional that is registered with the National Automotive Service Task Force (NASTF) Vehicle Security Registry. For help with your vehicle security credential please contact the NASTF Vehicle Security Professional help desk at 810-289-4809 or email support@nastf.org.
2013
Fusion, MKZ
2015
2016
2017
I own a 2017 Escape S 2.5 and have programed a second key with Forescan. I do NOT have a VSC. I purchased the vehicle with only 1 key. Bought an uncut key on ebay (correct transponder #) had it cut and added key with forscan. Two weeks ago I replaced the orginal BCM (because of parasitic draw) and when attempting to program the existing keys for replacement BCM forscan gave an error of Suspect incompatible key. After 2+ hours of digging around I found the PATS 5 amp fuse was blown in the salvage car BCM. Replaced fuse and in 3 minutes I had programed the 2 keys to vehicle and had it started.
Have I just been lucky or what?
